Creating Directory Number Routing
To create DN routing:
  1. From the Studio menu, select Show Design Perspective.
  2. From the Studio menu, select New, then select Activation, and then select DN Routing Map.
    The DN Routing Map Wizard appears.
  3. Select a project for this element and enter a name for the entity.
  4. (Optional) Select a location for the entity.
    By default, Design Studio saves the entity to your default workspace location. You can deselect the Use recommended name and location check box and enter a folder name in the Folder field or select a location different from the system-provided default.
    To select a different location:
    1. Deselect the Use recommended name and location check box.
    2. Click the Folder field Browse button.
    3. Navigate to the directory in which to save the entity.
    4. Click OK.
  5. Click Finish.
    In the Studio Projects view, in the project folder, the new DN routing map entity appears.
