Defining Action Processor Properties
The steps for defining action processor properties depend on the type of action processor you want to use.
Do one of the following:
To use the action processor that auto-generates functional Java files that include classes and methods configured for the command-line interface (CLI) protocol and attributes you selected, follow the steps in "Defining properties for the CLI Code Generation Action Processor".
To use the action processor that auto-generates Java stub files and provides the framework of classes and methods, follow the steps in "Defining properties for the Java Action Processor (with Code Generation)".
To associate an action processor with pre-written Java classes and methods, follow the steps in "Defining Java Action Processor (Without Code Generation)".
To associate an action processor with a state table, follow the steps in "Defining State Table (Without Code Generation)".
