Configuring Service Action, Atomic Action, and Action Processor Properties
You define the properties of service actions, atomic actions, and action processors in their respective editors.
See the following topics:
If you create compound parameters, Oracle recommends that you define the members for every compound parameter. This is beneficial once the code is generated during implementation. Ensure your parameters are valid Java parameters. See ASAP Cartridge Development Guide for more information.
