Grouping Scalar Parameters using Structured Elements
You can group ASAP scalar parameters using a structured data element. A structured data element is a container that holds ASAP parameters. The following scalar groups are defined using two levels of structured data elements:
Structure element1
Structure element2
Scalar1
Scalar2
Structure element3
Structure element4
Scalar3
Scalar4
For example, these structured data elements might be defined as:
Person
Name
First_name
Last_name
Place
Address
Number
Street
The structured data elements used in Design Studio are converted into individual ASAP scalar parameters by absorbing the structured data element names into the scalar parameter name. The previous example would appear as follows:
Person_Name_First_name Person_Name_Last_name Place_Address_Number Place_Address_Street
The default character used to separate the elements in the ASAP parameter names is the underscore (_). You can change this character. See "Activation Preferences Page" for more information.
To group scalar parameters:
From the Studio menu, select Show Design Perspective.
Click the tab for the Dictionary view.
Right click in the Dictionary view and select Add Structured Schema Element.
The Create Data Schema Structure wizard appears.
Enter the following:
In the Entity field, enter the name of the project to which you want to add a scalar parameter.
In the Name field, enter an element name.
In the Display Name field, enter a display name. The Data Schema editor supports multiple languages for this field. The field adjacent to Display Name displays your language. You can define a Display Name field value for any language you select from the list. For more information, see the Oracle Communications Design Studio Help.
In the Multiplicity field, select one of the following:
Required: This attribute makes the parameter mandatory.
Optional: This attribute makes the parameter optional.
Range: Any ranged parameter with a Minimum value greater than 0 is considered a mandatory ASAP parameter. Any ranged parameter with a Minimum value of 0 is considered an optional ASAP parameter.
Click Finish.
The new parameter appears in the Dictionary view. You may need to expand the schema for your cartridge to see it.
Double-click the new parameter to open the Data Schema editor with that parameter selected.
Click the Activation subtab.
From the Runtime type list, select SCALARS.
Right click the new parameter in the Dictionary view and select one of the following:
Add Simple Child Schema Element: Select this attribute if you want to immediately define xml or scalar parameters within the first structured element. If you select this option, go to step 10.
Add Structured Child Schema Element: Select this attribute if you want additional structured child schema elements below the first structured element. If you select this option, repeat steps 4 to 9.
Click Finish.
Repeat steps 10 to 11 for any additional parameters to be included in the scalar or XML parameter group.
