Creating Activation Run-Time Type Parameters in the Data Dictionary
You create activation run-time type parameters that can be used in the linked entities in their respective editors (you can also do this before linking the entities).
If you want to use the automatically generated code (see "Defining Action Processor Properties") and if you want the code to include content that support parameters, you must first create the parameters and associate them to atomic actions (see "Defining Atomic Action Properties") before generating the code.
For more information about activation parameters, see ASAP Cartridge Development Guide.
Design Studio supports the following:
