Running Activation Test Cases
After you have created an activation test case (test work order), you can run it in different environments. The purpose is to test, in Design Studio, the activation order completion for a cartridge project to verify that a work order is sent to the ASAP environment.
You can run test cases for your project in 2 different ways:
From the Activation Test Case editor
You can run a single test case of your project in a selected environment.
From the Activation Project editor
You can run a single test case or multiple test cases of your project at the same time in a selected environment.
See the following topics:
