Running Test Cases from the Activation Test Case Editor
To run a test case from the Activation Test Case editor:
In the Test Execution area of the Activation Test Case editor, specify the following:
The Test Order Primary Key Pattern (for primary key).
The desired Timeout value for the test (default is 30 seconds)
The Order Completion Status you expect based on the parameters used (either orderCompleteEvent or orderFailEvent).
The activation order passes the test if it meets the expected result. For example, if the expected result for the order is to fail but it completes instead, then the order has failed the test.
The Environment in which you want to run your test.
Click Run to run the test.
A test status of PASS or FAIL appears in the Console view. Additionally, information will appear for problems encountered when running the test. If no problems are encountered and the order has passed, then Design Studio submits the work order to the ASAP environment.
