Activation Project Editor Testing Tab
Use the Testing tab to view ASAP test cases that you created for your projects and run them individually or simultaneously.
| Field | Use |
Environment |
Select a run-time environment that has configuration for an ASAP environment. |
Include all from Project |
Select to include all test case entities. |
Entity |
Displays activation test case entities. |
Status |
Displays the status of a work order. |
Run All |
Click to execute all test cases one by one in the run-time environment. |
Separate Console for each Test Case |
Select to open a different console window for each test case in a run-time environment. |
Select |
Click to add a test case entity from the project. |
Open |
Click to open a specific test case entity. |
Remove |
Click to clear a specific test case entity from the Testing tab. |
Run |
Click to execute a specific test case. |
