Importing Activation Cartridge Projects
You can import data from an external source into Design Studio workspace or load earlier versions of cartridge projects with legacy data definitions. This allows you to utilize the imported data or components and modify based on requirement.
When importing Activation cartridge projects into Design Studio, see the following topics:
