NE Template Editor Editor Tab
Use the Editor tab to define configuration values used to manage the connections to a network element.
| Field | Use |
Description |
Specify a description for the NE Template editor. |
Vendor, Technology, and Software Load |
Displays the vendor, technology, and software load for the NE template entity in the cartridge project. |
See the following topics:
