Target Network Elements Tab
Use the Target Network Elements tab to define the target network elements to which you can route atomic actions.
Field Use
Target Network Element, Atomic Action, and Description
Displays the values configured in the Target NE Details area.
Add
Click to add a new target network element.
Remove
Click to clear a target network element from the editor.
Target NE Name
Specify the name of a target network element to which you can route an atomic action.
Select
Click to select an atomic action to be routed through the target network element. Do not select a specific atomic action, if you want all the atomic actions to be routed to one network element.
Clear
Click to clear the atomic action for a specific target network element.
Description
Specify a description for the target network element.
