Activation Test Case Editor Service Actions Tab
Use the Service Actions tab to define service actions and their associated parameters for the test case.
Field | Use |
Add |
In the Service Actions area, click to add a service action to the editor. |
Remove |
In the Service Actions area, click to remove a service action from the editor. |
Open |
In the Service Actions area, click to open the service action editor for the selected service action. |
XML Value |
Click to specify the XML file associated with the service action parameter of XML type. |
Add |
In the Service Action Parameters area, click to add additional parameters for a specific service action in the Service Actions area. |
Remove |
In the Service Action Parameters area, click to remove service action parameters for a specific service action from the editor. |
