Service Bundle Editor SA Parameter Map Tab
Use the SA Parameter Map tab to associate upstream parameters with service action parameters. This association enables SRT to map the incoming data from the translated order to the selected service action to run for the service bundle.
| Field | Use |
| Source Type | Select a parameter in the Name grid and modify the value to any one of the following:
| Name | Specify a name for an upstream parameter and click Add. |
| Mapping Type | Select any one of the following:
| Add | Click to add a service action parameter to this tab. |
| Remove | Click to remove a user defined parameter from the service action parameter list. |
| Remove Invalid | Click to remove any unnecessary invalid parameter (a red circle with an X appears next to an invalid parameter) for the service bundle. |
| Clear | Click to clear the editable contents of the service action parameter such as Mapping Type, Source and Default. |
Related Topics
Mapping Upstream Interface Parameters to Service Action Parameters
