About Model Variables
Model variables are placeholders for environment-specific values that you intend to define at the time of deployment. You can create, add, or remove model variables, as necessary.
For example, consider that you must define the credentials used for running automated tasks in two different environments—your testing environment and your production environment—and that the value required by the testing environment is different than that required by the production environment. Rather than editing the variable value in the source code each time you deploy to one of these environments, you can create a model variable, then define environment-specific values for that variable.
Some Oracle Communications features do not support model variables.
