2 Working with Design Studio Projects
Projects contain folders and files representing entities that you use to model Oracle Communications Design Studio cartridges, which you deploy to servers. You can use projects for version management, sharing, and resource organization. All Design Studio configuration is contained in a project.
The most common types of projects you use in Design Studio are:
Cartridge projects, which contain collections of entities and supporting artifacts that represent a cartridge deployed to a run-time environment.
Model projects, which contain data models common to multiple cartridge projects.
Environment projects, which you use to manage attributes associated with your run-time environments.
When working with projects, see the following topics:
