Unsealing Projects
Design Studio projects can be sealed to prevent changes to the project data. If you intend to make changes to a sealed project, you must first unseal the project.
To unseal a project:
In the Studio Projects view, double-click a Project entity for the project that you want to unseal.
The Project entity opens in the Project editor.
Click the Properties tab.
Click Unseal.
Before unsealing a project, carefully consider the terms of the license agreement.
Click OK.
Design Studio unseals the project and automatically initiates a build.
