Closing Projects
To reduce the amount of memory required and to improve build times, you can close projects not in use. When you close a project, the resources no longer appear in the workbench area. The projects remain in your local file system, and you can reopen them at any time.
Oracle recommends that you close projects from the Studio Projects view context menu, as described below.
To close a project:
From the Studio Projects view, right-click an open project.
The context menu appears.
Select Close Project.
Oracle Communications Design Studio prompts you to save any unsaved work in the resources directory. You can select specific files to save from a list of unsaved files.
Related Topics
