Opening Projects
You can keep multiple projects open in your workspace. Resources included in open projects are available for modeling.
Oracle recommends that you open projects from the Studio Projects view context menu, as described below.
To open a project:
From the Studio Projects view, right-click a closed project.
The context menu appears.
Select Open Project.
The project becomes active and the project resources are available for use in Design Studio.
Related Topics
