Exporting Projects
To facilitate sharing projects across teams, you can export projects to archive files. The archive files can be subsequently imported into a different Design Studio workspace.
To export a project from Design Studio:
From the File menu, select Export.
The Export dialog box appears.
Expand the General folder.
Select Archive File.
Click Next.
The Archive File dialog box appears.
Select the projects and resources to export.
In the To archive file field, specify the location of the archive file.
Or click Browse to locate the archive file.
In the Options area, select the following:
The archive file format
Your compression preferences
The Create directory structure for files option
Click Finish.
Design Studio creates the archive file in the specified location.
Related Topics
