Importing Projects into Design Studio Using Archive Files
To import projects in Design Studio using the archive file:
From the Studio menu, select Show Design Perspective.
Click the Studio Projects tab.
The Studio Projects view appears.
Right-click in the Studio Projects view and select Import, and then select Import Project.
The Import Projects dialog box appears.
Select Select archive file.
Click Browse.
Navigate to archive file and select it.
Click Open.
In the Projects area, select the project to import.
Click Finish.
Design Studio adds the project to your workspace.
If you import projects that have dependencies to other projects that are not in the current workspace, Design Studio displays an error. Import all dependent projects first, then clean all projects to remove the errors. See "Running Clean Builds" for more information.
