About Project Version Numbers
Design Studio supports both a three-segment and a five-segment release version. You can define release version numbers for any unsealed and editable Design Studio project.
Projects must always have a valid version number. When you first create a project, Design Studio applies the following default values:
Major Version Number: 1
Minor Version Number: 0
Maintenance Pack: 0
Generic Patch: 0
Customer Patch: 0
The build number is automatically generated through the build process.
When you edit any of these fields, you create a new version of the project.
Modifying these field values does not create a separate instance of the project in Design Studio, and Design Studio cannot support multiple versions of a project in the same workspace. Multiple versions of a project in the same workspace creates conflicting model entities.
When changing version numbers, Oracle recommends that you use a source control system to ensure that you are able to return to the previous version.
