Action Editor Properties Tab
Use the Properties tab to review or define information about the action and to define how the action realizes.
| Field | Use |
Action Type |
Displays the functional area to which the action belongs, such as Service or Technical. Click Select to define the action with a different action type. |
Subject |
Displays the conceptual model entity with which the action is associated. Click Select to associate the action with a different entity. |
Extend Subject |
If selected, indicates that the data elements defined on an associated conceptual model entity are inherited by the action. |
Target |
Select the resource (or, in a limited number of scenarios, the resource facing service) against which the technical action family executes. |
Key |
Enter a value to enable the Order and Service Management order transformation manager to identify the payload of a line item at run time. The default value for this field is the name of the entity. You can define a different key value for an entity if your business processes require a naming convention less restrictive than then entity name requirements. |
Implementation System |
Define the system where the application entity is used. Select one of the following:
Note: The design patterns that are delivered with Design Studio and that realize the conceptual model entities add configuration to your workspace only if you define this field with the Unified Inventory Management value. |
Realization Design Pattern |
Select which design pattern converts the action into an application entity and creates the application entity configuration in the workspace. |
Implementation Method |
Specify the application entity into which the action realizes. Select:
Run Realization Design Pattern Automatically |
Select to synchronize the action and application entities automatically. When you select this option, Design Studio runs a design pattern automatically when you:
See "Synchronizing Conceptual Model Entities with Application Entities" for more information. |
Realized By |
Displays the name of the application entity realized from the action. This field is blank if the design pattern selected in Realization Design Pattern has not yet run. |
