Action Code Editor
Use the Action Code editor to review the functional areas (or action types) to which the action code belongs. The action codes delivered with Design Studio are defined in the Common Model Base Data cartridge project. See "Generating the Common Model Base Data Project" for more information.
| Field | Use |
Functional Area |
Displays the list of functional areas in which the action code is included as a default value. Do one of the following:
