Conceptual Model Editor Data Elements Tab
Use the Data Elements tab to add simple and structured data elements to a conceptual model entity from a data schema. For example, a customer facing service that you model for a broadband service might include the UploadSpeed and DownloadSpeed data elements to represent the service speeds requested by a customer order.
The Data Elements area data tree displays a hierarchical representation of data elements modeled for the entity.
Conceptual model editors include context menu actions that you access by right-clicking in the Data Elements area data tree. The context menu options that are available depend on the selection in the view. See "Modeling Data Using Context Menus" for more information.
When adding data elements to a conceptual model entity, see the following topics:
