Dictionary View
Use the Dictionary view to display all data elements for every entity that contributes to the Data Dictionary. The root element is read-only.
You can use this view to create and manage data elements. For example, you can use this view to add elements to data schemas or to refactor data elements.
Additionally, you can use this view to model entities by dragging data from this view into an entity editor. See "Dragging Elements from the Dictionary View" for more information. Also, you can double-click the data element to open the element in the source entity editor.
| Action | Location | Use |
Show Only Root Simple Element |
Toolbar |
Click to display all root level simple elements. Disable to display root level simple and root level structured data elements. |
Filters elements inherited through entity extension |
Toolbar |
Click to display only data elements that inherit from a base type. Inherited elements (structured or simple) are defined using a base type as the data type. |
Filters elements not visible to the active editor based on project dependencies |
Toolbar |
Click to display only those elements available to the active editor, based on the project dependencies. See "Project Editor Dependency Tab" for information about defining project dependencies. |
Clear Filter |
Toolbar |
Click to remove all previously defined filters: all data elements in the workspace appear in the view. |
Filter Menu |
Toolbar |
Click to access two sets of view filters: the Tags filter and the Entity Type filter. In the Tags area, select:
In the Entity Type area, select:
Element Entity Name |
Toolbar |
Search for specific data elements, such as a specific address or person, or for specific entities. Enter terms into these fields and click the Filter button to search for the term. Click the Filter button again to clear the search term. When filtering, consider the following:
Add Simple Schema Element |
context menu |
Right-click a Schema entity to add a new global simple schema element (an element that has no associated parent structure) to a data schema. A simple schema element cannot contain any child elements. See "Creating Simple Data Elements" for more information. |
Add Structured Schema Element |
context menu |
Right-click a Schema entity to add a new global structure (a structure that has no associated parent structure) to a data schema. Structures are complex data types that include embedded data types. See "Creating Structured Data Elements" for more information. |
Add Structured Child Schema Element |
context menu |
Right-click a structured data element to add a new child structure (a structure that is included in a parent structure) to a data schema. Structures are complex data types that include embedded data types. See "Creating Structured Data Elements" for more information. |
Add Simple Child Schema Element |
context menu |
Right-click a structured data element to add a new child schema element (an element that is included in a parent structure) to a data schema. See "Creating Simple Data Elements" for more information. |
Delete |
context menu |
Select to permanently remove the schema element from a data schema. This action is not available for root level elements (those that represent the entity name). |
Move Up |
context menu |
Select to move a data element (and the children, if applicable) to a higher position within the set of child data elements. You can move data elements when:
Move Down |
context menu |
Select to move a data element (and the children, if applicable) to a lower position within the set of child data elements. You can move data elements when:
Refactoring |
context menu |
Select to access a menu of options that enable you to propagate data model changes across a solution without sacrificing model integrity. See "Refactoring Entities and Data Elements" for more information. |
Related Topics
