Data Dictionary Preferences Editor
Use the Data Dictionary preferences page to specify the expansion level of the Data Dictionary.
| Field | Use |
Expansion Level |
Enter the tree depth to which the Data Dictionary tree can expand. The default is 6. If you change the default setting, you must restart Design Studio for the change to take effect. Note: Expanding the tree depth above 9 may adversely affect system performance. |
Related Topics
