Defining Data Dictionary Preferences
You define Data Dictionary preference settings to specify the tree depth to which the Data Dictionary tree can expand.
To define Data Dictionary preferences:
From the Window menu, select Preferences.
The Preferences dialog box appears.
In the left-column menu tree, expand the Oracle Design Studio folder.
Click Data Dictionary.
See "Data Dictionary Preferences Editor" for more information.
In the Expansion Level field, specify the tree depth to which the Data Dictionary can expand.
Click Apply.
Click OK.
Design Studio restarts.
