Displaying Editors
Design Studio editors are associated with entities. Many Design Studio views enable you to double-click on entities to open the entity in the associated editor. For example, you can double-click an entity in the Solution view or Studio Projects view to open the associated editor. Additionally, you can double click on table entries that reference entities to open the entity in the associated editor.
See the Eclipse Workbench User Guide for more information about associating editors with file types.
You can open entity editors at any time to modify existing projects and elements.
To display the editor for a project or element:
From the Studio menu, select Show Design Perspective.
Click the Studio Projects tab.
The Studio Projects view appears.
Double-click a project or entity.
The editor associated with the entity appears, enabling you to view and edit the information. For example, if you double-click a Project entity, the entity opens in the Project editor (you can also double-click a project folder to open the Project entity in the Project editor).
Related Topics
