Defining Editor Preferences
The Design Studio Workbench supports multiple open editors at any one time. You can define preferences to control editor behavior across a workspace. For example, you can define the number of open editors allowed to ensure that Design Studio does not run out of available resources.
To define Design Studio editor preferences:
From the Windows menu, select Preferences.
The Preferences dialog box appears.
Expand the General directory.
Click Editors.
The Editors preferences page appears. See the Eclipse Help for more information about the fields on this page.
(Optional) Select Close editors automatically.
(Optional) In the Number of opened editors before closing field, indicate the number of editors that can remain open at any one time.
The system automatically closes a previously opened editor if you exceed this number of open editors.
Click OK.
Design Studio saves your changes and closes the Preferences dialog box.
Related Topics
