Data Schema Editor Data Element Tab
Use the Data Schema editor Data Element tab to view a hierarchical representation of data elements in the schema, and to access a common set of subtabs that enable you further refine entities and data elements.
When modeling data in the Data Schema editor Data Element tab, see the following topics:
| Field | Use |
Type |
Select a specific data type to limit the nodes that appear in the Dictionary area to structured data elements or simple data elements. |
Filter |
Search for specific data nodes, such as a specific address or person. When using the Filter field, consider the following:
Clear Filter button |
Remove all criteria from the Filter field. |
