Defining Character Encoding at the Workspace Level
To define the character encoding scheme for the entire workspace:
From the Design Studio Window menu, select Preferences.
The Preferences dialog box opens.
Expand General and then click Workspace.
The Workspace page appears.
In the Text file encoding field, select Other and then select an encoding value.
Click Apply, then click OK.
