Defining Character Encoding
You can define character encoding at the workspace level, at the editor level, or for specific text files. The default character encoding scheme in Eclipse is cp1252. You may be required to change this scheme, for example, if you intend to submit orders that contain character sets from languages such as Chinese, Japanese, or Norwegian. In this case, you can define the character encoding scheme as UTF-8.
When working with character encoding, see the following topics:
