Resolving OSM Solution Build Timeout Failures
If the OSM Solution Automation build fails due to a SocketTimeOut exception, increase the value of the Separate JRE timeout setting.
To increase the value of the Separate JRE timeout setting:
In Design Studio, from the Window menu, select Preferences.
In the Preferences navigation tree, select Ant.
In the Separate JRE timeout (ms) field, enter 40000.
Click OK.
