Resolving Import Project Errors
If you are not able to import projects into Design Studio successfully, you may be using an incorrect import method. There are two different import methods available in the Design Studio interface: an Eclipse method and a Design Studio method. Always use the Design Studio method. Import projects using the Studio Projects view context menu or with the Import Studio Project menu action available in the Studio menu. Using the Eclipse import functionality (available by selecting File, then Import) is not recommended, as it may cause unpredictable results and may require that you restart Design Studio.
