Fulfillment Function Editor
Use the Fulfillment Function editor to define the functions that represent the work to be performed against an action.
| Field | Use |
Implementation System |
Define the system where the application entity is used. Select one of the following:
Implementation Method |
Specify how the Fulfillment Function entity realizes as an application entity. Select:
Realization Design Pattern |
Select the design pattern that converts the Fulfillment Function entity into an application entity and creates the application entity configuration. |
Run Realization Design Pattern Automatically |
Select to synchronize the Fulfillment Function entity and the realized application entity automatically. When you select this option, Design Studio runs a design pattern automatically when you:
See "Synchronizing Conceptual Model Entities with Application Entities" for more information. |
Realized By |
Displays the name of the application entity realized from the Fulfillment Function entity. This field is blank if you have not yet realized the Fulfillment Function entity. Click Open to open the selected application entity editor. |
