Fulfillment Pattern Editor
Use the Fulfillment Pattern editor to define the functional area (such as customer, service, or technical) that the pattern supports, the provider functions that are associated with the pattern for a group of related products in a product catalog, and the fulfillment functions that the pattern supports.
| Field | Use |
Implementation System |
Define the system where the application entity is used. Select one of the following:
Implementation Method |
Specify how the Fulfillment Pattern entity realizes as an application entity. Select:
Realization Design Pattern |
Select which design pattern converts the Fulfillment Pattern entity into an application entity and creates the application entity configuration. |
Run Realization Design Pattern Automatically |
Select to synchronize the Fulfillment Pattern entity and the realized application entity automatically. When you select this option, Design Studio runs a design pattern automatically when you:
See "Synchronizing Conceptual Model Entities with Application Entities" for more information. |
Realized By |
Displays the name of the application entity realized from the Fulfillment Pattern entity. This field is blank if you have not yet realized the Fulfillment Pattern entity. Click Open to open the selected application entity editor. |
Functional Area |
Associate a functional area to the fulfillment pattern. Do one of the following:
Provider Function |
Associate a provider function to the fulfillment pattern. Do one of the following:
Fulfillment Function |
Associate fulfillment functions to the fulfillment pattern. Do one of the following:
Related Topics
