Navigating Among Multiple Editors
When you have multiple editors open, select Navigate, then select Back to access a list of previously used editors (Alt key + e). Also, you can through the editor list by pressing the Alt key and the left arrow to return to a previously used editor and the Alt key and the right arrow to move back.
By default, the Studio Projects view is linked to the currently open editor. For example, closing or switching editors does not change the highlighted selection in the Studio Projects view. To always display in the Studio Projects view the file currently being edited, ensure that the Link to Editor button in the Studio Projects view toolbar is enabled.
