Defining Entity Notes
Some Design Studio editors include a Notes button that you can use to attach documentation to an entity. For example, you can contribute content to Design Studio reports by writing your own internal documentation about entities and data elements, and you can format the documentation using plain text or simple HTML.
To define notes for an entity:
  1. From the Studio Projects view, double-click an entity.
    The entity opens in the appropriate editor.
  2. Click the Notes button.
    This button is located in the top right corner of Design Studio editors and is represented by a note pad, pencil, and lowercase letter "i" icon.
  3. Enter information about the entity.
  4. Do one of the following:
    • Press F2 to apply the changes.
    • Press Esc to close the text box without saving changes.
