About OSM Cartridge Management Variables
Design Studio for OSM provides the following default cartridge management variables:
Use the same default value for variables that are defined in multiple cartridges in a workspace. If different values are used, a warning appears in the Problems view.
| Default Variable | Use |
DEFAULT_CARTRIDGE |
This variable indicates whether the current version of the cartridge is the default version in the namespace. Cartridges that you deploy to OSM must have a default version. Specifying a default cartridge ensures that orders submitted by Task web client users who are not defined with permission to create versioned orders are handled correctly in the OSM run-time environment. At run time, if a user who does not have permission to create versioned orders enters an order, the OSM server submits the order to the default cartridge. See "Role Editor Role Tab" in Modeling OSM Processes for more information about granting permissions to roles. Set this variable to one of the following values:
Note: If you have multiple versions of a composite cartridge, for each composite cartridge you should set this variable to the same value for the composite cartridge and all of the component cartridges that it references. Only one of the composite cartridges should have this variable set to true. |
ENTITY_CONFLICT_ACTION_ON_DEPLOY |
This variable determines system behavior when cartridges are being updated with a new version and conflicting entities are found. It applies only if PURGE_CARTRIDGE_BEFORE_DEPLOY is set to false. Set this variable to one of the following values:
FAST_CARTRIDGE_UNDEPLOY |
This variable determines system behavior when undeploying cartridges. Set this variable to one of the following:
NODE_REMOVAL_ALLOWED_ON_REDEPLOY |
This variable determines whether to allow users to remove a node from an order template and redeploy cartridges. Set this variable to one of the following:
PURGE_CARTRIDGE_BEFORE_DEPLOY |
This variable determines system behavior when you are deploying a new version of a cartridge to an OSM environment where an older version of the cartridge is already deployed. Set this variable to one of the following values:
PURGE_ORDER_ON_UNDEPLOY |
This variable determines system behavior when you try to undeploy cartridges that have pending orders. Set this variable to one of the following values:
If you attempt to undeploy a cartridge that is not present in your workspace, and if the PURGE_ORDER_ON_UNDEPLOY option is defined as Inherit on the Cartridge Management Variables tab of the Studio Environment editor, then Design Studio defines the PURGE_ORDER_ON_UNDEPLOY option as false, even if the deployed cartridge includes a PURGE_ORDER_ON_UNDEPLOY option that is defined as true (on the Order and Service Management Project editor Cartridge Management Variables tab). To change this behavior, select the PURGE_ORDER_ON_UNDEPLOY option in the Cartridge Management Variables tab of the Studio Environment editor, then select Override, and then define the option as true. Caution: Undeploying a cartridge using the forced undeploy option purges all existing orders for that cartridge. |
SUSPEND_DB_JOBS_TIMEOUT |
This variable determines the amount of time the database jobs remain in a suspended state. Before importing a cartridge, the OSM server ensures that the OSM database jobs have stopped. If a variable is not specified, the default value of 0 is used, which indicates infinite time. |
UNDEPLOY_SHARED_CARTRIDGE |
(Composite cartridges only.) This variable determines system behavior when undeploying a composite cartridge. See "Undeploying Composite Cartridges with Shared Component Cartridges" for more information. Set this variable to one of the following values:
Oracle recommends that you do not remove any of the default cartridge management variables.
You can define and use the following optional cartridge management variables:
| Optional Variable | Use |
BUILD_DEPLOY_MODE |
This variable determines how the system will build and deploy cartridges targeted at versions of OSM prior to 7.3. Do not use this variable for OSM 7.3 or later OSM servers. Set the variable to one of the following values.
See "Defining Order and Service Management General Preferences" for information about automation plug-in build-and-deploy modes. Tip: How you build and deploy automation plug-ins (the build-and-deploy mode) indicates whether you want the plug-ins to be able to run within the oms.ear file or not. The automation plug-in dispatch mode set on the OSM server indicates the ability for OSM to invoke an automation plug-in that is running within the bounds of the oms.ear file. |
XML_CATALOG_SUPPORT |
This variable determines whether XML Catalog support is enabled. It is enabled by default and is required to be enabled. When you deploy to some target run-time software versions, you can disable XML Catalog support. See "Working with XML Catalogs" for more information on using XML Catalogs.
Related Topics
