Outline View
Use the Outline view to view relationships, entities, and data elements related to the entity in the active editor. Also, you can perform operations on those relationship folders, entities, and elements.
The Outline view is linked to the editor in focus. When you switch editors, Design Studio updates the content in the Outline view based on the active selection.
The Outline view enables you to navigate through and to perform operations on relationships, entities, and data elements while maintaining focus on the active entity or data element. See "Refactoring Entities and Data Elements" for more information about the operations that you can perform on data elements in this view.
