Notes View
Use the Notes view to provide documentation for the entity or data element selected in the Solution view. You can annotate entities and data elements when you want to communicate to other team members information about the solution.
For example, you can contribute content to Design Studio reports by writing your own internal documentation about entities and data elements, and you can format the documentation using plain text or simple HTML. See "Notes Tab" for more information.
The Notes view is linked to the Solution view, the Studio Projects view, and the Package Explorer view. When you make a selection in any of these views, Design Studio updates the content in the Notes view based on the active selection.
