Resolving Invalid Problem Markers
Invalid problem markers (for example, those that continue to reappear after you fix the corresponding problem in the configuration), can usually be removed by running a clean and build. When you run a clean and build, Oracle Communications Design Studio discards all build problems and built states of the selected projects and rebuilds those projects from scratch.
See "Running Clean Builds" for more information.
