Resolving Plug-in Compatibility Issues
Oracle Communications Design Studio does not load Design Studio plug-ins when you are using an unsupported version of the Java Developer Kit and Runtime Environment. If no Design Studio plug-ins load at startup, ensure that you update the Design Studio version to the latest service pack, and that you are using the recommended Java Runtime Environment and Java Developer Kit versions. See Design Studio Installation Guide for more information about system requirements.
