Synchronization Record Editor Synchronization Details Tab
Use the Synchronization Details tab to review information about the design pattern and the project associated with the synchronization record.
| Field | Use |
Design Pattern |
Displays the design pattern associated with the synchronization record. |
Time Stamp |
Displays the date and time when the design pattern last ran. |
Synchronization Subject |
Displays the conceptual model entity against which the design pattern ran. |
Projects area |
Displays all design pattern project tokens and the values supplied for those project tokens. Tokens are placeholders that represent information to be collected by the Design Pattern wizard from a user applying a design pattern. Tokens ensure that the resources a design pattern copies to a workspace are based on information supplied by the user who applies the design pattern. See the Design Studio Developer's Guide for more information. |
Project Token |
Displays the design pattern project token selected in the Projects area. |
Value |
Displays the value of the selected token supplied by the user who applied the design pattern. |
