Synchronization Record Editor Token Values Tab
Use the Token Values tab to review the tokens defined in the design pattern and the values supplied by the user who last applied the design pattern.
| Field | Use |
Tokens area |
Displays all of the design pattern tokens (that do not collect project information) and the values supplied for those tokens. Tokens are placeholders that represent information to be collected by the Design Pattern wizard from a user applying a design pattern. Tokens ensure that the resources a design pattern copies to a workspace are based on information supplied by the user who applies the design pattern. See the Design Studio Developer's Guide for more information. |
Token |
Displays the design pattern token selected in the Tokens area. |
Value |
Displays the value of the selected token supplied by the user who applied the design pattern. |
