Synchronization Record Editor References Tab
Use the References tab to review the element and entity reference tokens defined in a design pattern.
| Field | Use |
Element Tokens area |
Displays all of the design pattern tokens and the values supplied for those tokens. Tokens are placeholders that represent information to be collected by the Design Pattern wizard from a user applying a design pattern. Tokens ensure that the resources a design pattern copies to a workspace are based on information supplied by the user who applies the design pattern. See the Design Studio Developer's Guide for more information. |
Entity Tokens area |
The Token field displays the design pattern token selected in the Tokens area. The Value field displays the value of the selected token supplied by the user who applied the design pattern. Click Select to change the value. Click Value to open the token value in the appropriate Design Studio editor. |
