Action Editor Details Tab
Use the Details tab to specify general details about the action.
| Field | Use |
| Description | Enter a short description of the action. |
| Implementation Prefix | Displays the implementation prefix. Design Studio creates the implementation prefix from the entity name and removing any invalid Java characters. |
| Abstract | Select to specify whether the action is abstract. See "About Abstract Actions for Network Integrity" for more information. If the action is abstract, then it can only be used as a component within another action. If the action is not abstract, then it can be deployed and a scan can be executed from it. |
| Address Handler | Specify the address handler for the action. Use the Select button to choose an address handler from a list of dependent cartridge projects. This field appears for assimilation, discovery, and import actions only. |
| Result Categories | Add result categories to the action. This field appears for assimilation, discovery, and import actions only. |
| Documentation | Add any other information about the action. |
