Action Editor Processors Tab
Use the Processors tab to view and manage the processors on an action.
Action Processors Area
| Field | Use |
Action Processors table |
Lists all processors on the action by name and provider and indicates whether the processor has any conditions set.The Owner Action column identifies processors added from other actions. |
Move Down Move Up |
Select a processor and click to change the order of the processors in the Action Processors table. |
Select |
Add existing processors and actions from dependent cartridge projects to the action. |
Open |
Open the Processor editor for the selected processor. |
Remove |
Remove the selected processor from the action. |
Add For Each |
Add a For Each processor to the action. |
Add |
Create a new processor to add to the action. |
Conditions Area
| Field | Use |
Conditions table |
Displays the condition applied on the selected processor from the Action Processors table. Set to true to run the processor when the condition is true. Set to false to run the processor when the condition is false. |
Remove |
Remove the selected condition. |
Select |
Add an existing condition to the selected processor. |
Related Topics
About Network Integrity Actions
Configuring Network Integrity Actions
Working with Network Integrity Processors
Adding Existing Processors to Network Integrity Actions
Adding New Processors to Network Integrity Actions
Adding For Each Processors to Network Integrity Actions
