Adding New Processors to Network Integrity Actions
You can create a new processor from the Action editor to add to your action.
To create a new processor and add it to an action:
  1. On the Action editor Processors tab, click Add.
    The Studio Model Entity Wizard appears.
  2. From the Project list, select the cartridge project that contains the action in which you are creating the processor.
  3. From the Type list, select the type of processor you want to create.
    The Type list contains different processor types depending on the action you are configuring.
  4. In the Name field, enter a name for the processor.
    The Implementation Prefix field takes the component name by default.
  5. (Optional) In the Folder field, select a location for the processor.
    If you leave the Folder field blank, the processor is created in the default workspace.
  6. Click Finish.
    Design Studio creates the processor and adds it to the Action Processors area.
  7. Save the action.
  8. Configure the processor.
    See "Configuring Network Integrity Processors" for more information.
