Adding Result Categories to Network Integrity Actions
Assimilation, discovery, and import actions must have a valid result category.
To add a result category to an action:
                     On the Action editor Details tab, in Result Categories area, click Add. The Create Results Categories dialog box appears.
                     In the Name field, enter a name for the result category. Note: The name of the result category must match the name of the result group in the Java implementation into which the scan results are saved. The result category name also appears in the Network Integrity UI scan results.
                     (Optional) In the Description field, add information about the result category.
                     Click OK.
                     Save the action.
